hm_modent_getrepresentationdefinitions
Returns the number of modular entity representations available, and those realized.
hm_modent_getrepresentationdefinitions entity_type mark_id ?ignoretransient=<value>? ?libraryinfo=<value>?
HyperMesh Tcl Query Command
They are returned by their representation keys (identifier). For example:
{Crash5} { available 2 realized 1 }
{Crash10} { available 1 realized 0 }
- entity_type
- The modular entity type. Supported for parts and subsystems.
- mark_id
- The ID of the mark containing the modular entities. Valid values are 1 and 2.
- ignoretransient=<value>
- 0 - Return all representations
- libraryinfo=<value>
- 0 - No library info provided
Examples
To get the saved representations that are available, and those realized, for subsystems on
mark 1:
*createmark subsystems "by id only" 4 6 8
hm_modent_getrepresentationdefinitions subsystems 1 ignoretransient=0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
2024 - Added parts to supported entity types.
