hm_getmodelcheckdisplaynames
Returns check display names.
hm_getmodelcheckdisplaynames ?check_type? ?entity_type?
HyperMesh Tcl Query Command
- check_type
- The type of check, ERROR, WARNING, INFO or ALL. If blank, then all checks of all types are returned.
- entity_type
- The type of entity. If ALL, then checks for all entity types in the profile are returned.
Examples
To get the check names for all check and entity
types:
hm_getmodelcheckdisplaynamesor
hm_getmodelcheckdisplaynames ALLTo get the check names for ERROR for mats:
hm_getmodelcheckdisplaynames ERROR mats
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
