hm_attributetype
Returns the attribute type number of an attribute for the current template.
hm_attributetype attribute_name_or_id
HyperMesh Tcl Query Command
Returns the attribute type number of an attribute for the current template. If the
attribute is not an attribute from the current template, an error is returned. The values
returned have the following meanings:
- 1 - integer
- 2 - double
- 3 - string
- 4 - 1D integer array
- 5 - 1D double array
- 6 - entity
- 7 - (not supported)
- 8 - (not supported)
- 9 - 2D integer array
- 10 - 2D double array
- 11 - string array
- 12 - 1D entity array
- 13 - 2D entity array
- attribute_name_or_id
- The name or ID of the attribute to query. The attribute must be in the current template.
Examples
To get the attribute type number of the attribute named LSD_PID for the LS-DYNA template:
hm_attributetype LSD_PID
To get the attribute type number of the attribute ID 149 for the LS-DYNA template:
hm_attributetype 149
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-110
