hm_getactiveplotcontrolid
Returns the active plot control ID for a particular result plot type.
hm_getactiveplotcontrolid plot_type
HyperMesh Tcl Query Command
Returns the active plot control ID for a particular result plot type. There can be only one active plot control for every plot type.
- plot_type
- The type of result plot. Valid values are contour, vector, tensor, deformed, and marker.
To query the ID of the active contour plot
control:
hm_getactiveplotcontrolid contourErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
2022.3 - Added support for new plot_type marker.
