hm_getmodelcheckdefaultconfigfile
Returns the default model check config file for a profile.
hm_getmodelcheckdefaultconfigfile ?profile?
HyperMesh Tcl Query Command
If a user specified config file is not present, then it gives the default config file provided in the installation.
- profile
- The name of a specific profile to query. If not specified, then the default config file for the current profile is returned.
Examples
To return the default config file for "LsDyna":
hm_getmodelcheckdefaultconfigfile "LsDyna"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
