hm_getnearbyentities
Finds entities nearby entities on an input mark.
hm_getnearbyentities inputentitytype=<input_entity_type> inputentitymark=<mark_id> outputentitytypes={<output_entity_type1> ?<output_entity_type2> ... <output_entity_typeN>?} outputentitymark=<mark_id> radius=<value> ?nearby_search_method=<method>?
HyperMesh Tcl Query Command
The options may be provided in any order.
- inputentitytype=<input_entity_type>
- The input entity type to find nearby entities to. Valid values are comps, elems, equations, loads, nodes, systems, vectors, points, lines, surfs, solids, parts, and connectors.
- inputentitymark=<mark_id>
- The ID of the mark of input entities. Valid values are 1 and 2.
- outputentitytypes={<output_entity_type1> ?<output_entity_type2> ... <output_entity_typeN>?}
- The list of output entity types to find. Valid values are comps, elems, equations, loads, nodes, systems, vectors, points, lines, surfs, solids, parts, connectors, and accelerometers.
- outputentitymark=<mark_id>
- The ID of the mark of output entities. Valid values are 1 and 2.
- radius=<value>
- The nearby search radius/size.
- nearby_search_method=<method>
- The optional search method, either box or sphere (default).
Examples
*createmark comps 1 "by id only" 301 302
hm_getnearbyentities inputentitytype=comps inputentitymark=1 outputentitytypes={loads elems} outputentitymark=2 radius=100 nearby_search_method=sphereErrors
# Handle error
}Version History
2020
2021.2 - Added new supported input entities: points, lines, surfs, solids, parts, and connectors. Added new supported output entities: points, lines, surfs, solids, parts, connectors, and accelerometers.
2022 - Added nodes as new supported output entity.
