hm_morph_getmvoledge
Returns the morph volume edge ID for the specified nodes along the edge.
hm_morph_getmvoledge node_1_id node_2_id
HyperMesh Tcl Query Command
- node_1_id
- The ID of the first node on the edge.
- node_2_id
- The ID of the second node on the edge.
To find the edge running through nodes with IDs 5 and 8:
hm_morph_getmvoledge 5 8
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
