hm_getadvancedselectiontypes
Returns a list of valid advanced selection strings for the specified entity type and mode.
hm_getadvancedselectiontypes entity_type ?mode?
HyperMesh Tcl Query Command
- entity_type
- The entity type to query.
- mode
- Specifies whether to return only the advanced options exposed in the GUI (0, default), or all options including those currently only exposed via Tcl (1).
Examples
To get the list of all advanced selection strings valid for
comps:
hm_getadvancedselectiontypes comps 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
