hm_morph_getinfo
Returns certain options/values from HyperMorph.
hm_morph_getinfo option ?value1? ?value2?
HyperMesh Tcl Query Command
- option
- There are different options available. Each requires its own format:
- domaincount
- domain_type
- domain_type
- The type of domain to count. Valid values are:
- 0 - All domains
- 1 - 1D domains
- 2 - 2D domains
- 3 - 3D domains
- 4 - Global domains
- 5 - Edge domains
- 7 - General domains
- excludedelements list
- Returns a list of all excluded element IDs.
- excludedelements mark
- mark_id
- parameter
- parameter_name
- parameter_name
- The parameter to query. See the documentation for *morphupdateparameter and *morphupdateparameterstring for a list of supported values.
- testlimits
- elem_type test_id
- undolist current
- Returns the current position in the undo/redo list.
- undolist maximum
- Returns the length of the undo/redo list.
Examples
To obtain the status and limits for the quad element Jacobian test:
hm_morph_getinfo testlimits 1 6
To get the number of 2D domains:
hm_morph_getinfo domaincount 2
To get the facecolor setting:
hm_morph_getinfo parameter facecolor
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
