hm_attributeindexentitytypename
Returns the entity type string of an indexed entity attribute on an entity.
hm_attributeindexentitytypename entity_type entity_name_or_id attribute_index ?search_type?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- attribute_index
- The index of the attribute owned by the queried entity (starting at 1).
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
To get the attribute entity type string of the entity attribute with index 4 on property 1:
hm_attributeindexentitytypename props 1 4 -byid
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-110
