hm_cardassignedtoentity
Indicates if a card can be assigned to the entities on the mark for the current template.
hm_cardassignedtoentity entity_type mark_id
HyperMesh Tcl Query Command
Returns 1 if a card can be assigned to the entities on the mark for the current template, 0 otherwise.
- entity_type
- The type of entity to query.
- mark_id
- The ID of the mark of entities to query. Valid values are 1 and 2.
Examples
To query components 100 and 101:
*createmark comps 1 100 101
hm_cardassignedtoentity comps 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
