hm_findadvancedselectiongroups
Finds advanced selection entities and separates them into selection method specific groups.
hm_findadvancedselectiongroups entity_type mark_id ?method? ?angle?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query. Must be set to surfs.
- mark_id
- The ID of the mark of entities to query. Valid values are 1 and 2.
- method
- The advanced selection method. Valid values are:
- angle
- The feature angle value used for faces detection. The value can be omitted, in which case the default feature angle value is used.
Examples
To find all groups of connected surfaces:
*createmark surfs 1 all
hm_findadvancedselectiongroups surfs 1 "by attached"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
