hm_getmark
Returns the entity IDs of the passed entity type on the specified mark.
hm_getmark entity_type mark_id ?panel_sensitive? ?model_name?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- panel_sensitive
- Deprecated. Always set to 0.
- model_name
- The optional model to get the mark for. If not specified, the current model is used.
Examples
To return the components on mark 1:
hm_getmark comps 1To return the components on mark 1 for model
model-2:
hm_getmark comps 1 0 model-2A mark of loads is created in the Delete panel. The Mask panel has been pushed using the
command "hm_pushpanel mask". A mark of loads is created in the Mask
panel. To get the list of loads on mark 1 created from the Mask
panel:
hm_getmark loads 1 1To get the list of loads on mark 1 created from the Delete
panel:
hm_getmark loads 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020 - Added new option model_name.
2023 - Deprecated argument panel_sensitive.
