hm_getinternalname
Returns the internal name for the specified pool string/pool ID and solver name.
hm_getinternalname id_pool solver_name search_type
HyperMesh Tcl Query Command
This command returns the internal name for the specified pool string/pool ID.
- id_pool
- The pool ID or name. By default, the value is assumed to be the pool ID. This is controlled by the optional search_type argument.
- solver_name
- The entity solver name.
- search_type
- Defines whether id_pool is specified as a pool name or a pool ID. Valid values are -bypoolid and -bypoolname. If not specified, it defaults to -bypoolid.
Examples
To get the internal name of the node set with solver name S1 by specifying the pool
name:
hm_getinternalname nset_idpool S1 -bypoolnameErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
