hm_attributenamefromid
Returns an attribute name from the attribute ID for the current template.
hm_attributenamefromid attribute_id
HyperMesh Tcl Query Command
Returns an attribute name from the attribute ID for the current template. If the attribute does not exist in the current template, an error is returned.
- attribute_id
- The ID of the attribute to query.
To get the attribute name of the attribute ID 100:
hm_attributenamefromid 100
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-110
