hm_morph_getmvolface
Returns the morph volume face ID for the specified morph volume and nodes along the edges of that face.
hm_morph_getmvolface mvol_id node_1_id node_2_id node_3_id
HyperMesh Tcl Query Command
- mvol_id
- The ID of the morph volume.
- node_1_id
- The ID of the first node on the edge.
- node_2_id
- The ID of the second node on the edge.
- node_3_id
- The ID of the third node on the edge.
To find the face of morph volume with ID 2 using nodes 5, 8 and 12:
hm_morph_getmvolface 2 5 8 12
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
