hm_getprefixbasenamesuffixforgivencompname
Returns the split name as prefix, base name and suffix for the specified component name and separator.
hm_getprefixbasenamesuffixforgivencompname name separator
HyperMesh Tcl Query Command
- name
- The name of the component.
- separator
- The character to be used to split the component name. The prefix is everything before the first instance of this character, the suffix is everything alphanumeric after the second instance of this character, and the base name is everything in between.
Examples
To get the prefix, base name, and suffix for a given name using - as the separator:
hm_getprefixbasenamesuffixforgivencompname abc-defgh-ijk.123 "-"
{abc defgh ijk}
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020.1
