hm_getfilletfacesbyprofile
Returns the faces containing fillets with a selected profile edge.
hm_getfilletfacesbyprofile entity_type mark_id
HyperMesh Tcl Query Command
- entity_type
- Must be set to lines.
- mark_id
- The ID of the mark containing the profile lines that define the fillets. Valid values are 1 and 2.
To get the faces with fillets with profile lines 5 and 15:
*createmark lines 1 5 15
hm_getfilletfacesbyprofile lines 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
