hm_getgeomtopologytype
Returns the topology type of a geometric entity.
hm_getgeomtopologytype entity_type id
HyperMesh Tcl Query Command
Returns the topology type of a geometric entity. Return types include:
- points - none, vertex, fixed
- lines - none, free, shared, nonmanifold, suppressed
- surfs - free, bounding, partition, fin
- solids - 1dmappable, 3dmappable, unmappable, ignoredmappable
- entity_type
- The type of entity to query. Valid values are points, lines, surfs and solids.
- id
- The ID of the entity to query.
To query the topology of surface 100:
hm_getgeomtopologytype surfs 100
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
