hm_holedetectionfindholes
Executes the hole/tube detection tools.
hm_holedetectionfindholes find
HyperMesh Tcl Query Command
Runs the hole detection functions for finding holes and tubes based on input entities and parameters. This must be preceded by calls to hm_holedetectioninit, hm_holedetectionsetentities, and hm_holedetectionsetholeparams or hm_holedetectionsettubeparams.
- find
- Bit value defining the types of holes and tubes to find (Bit0 + 2*Bit1 + 4*Bit2):
- Bit0
- 0 - Do not find holes
- Bit1
- 0 - Do not find 2D tubes
- Bit2
- 0 - Do not find 3D tubes
To write out all geometric shell hole details to a file named C:/temp/holes.txt:
set holesfile [open "C:/temp/holes.txt" "w"]
*createmark surfs 1 all
hm_holedetectionsetentities surfs 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
set n [hm_holedetectiongetnumberofholes]
if { $n > 0 } {
puts $holesfile "Number of holes = $n"
puts $holesfile "Holes details"
for {set i 0} {$i < $n} {incr i} {
puts $holesfile "i = $i [hm_holedetectiongetholedetails $i]"
} else {
puts $holesfile "Holes not detected."
hm_holedetectionend
close $holesfile
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
