hm_getprincipalaxes
Returns the principal axes direction cosines for the selected entities.
hm_getprincipalaxes entity_type mark_id ?location_flag?
HyperMesh Tcl Query Command
Returns the principal axes direction cosine values for the selected entities. The values are always returned relative to the global axes. The values are returned as 1st_direction_x 1st_direction_y 1st_direction_z 2nd_direction_x 2nd_direction_y 2nd_direction_z 3rd_direction_x 3rd_direction_y 3rd_direction_z.
- entity_type
- The type of entity to query. Currently supported for comps and elems.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- location_flag
- Optional. Specifies the location about which the principal axes are calculated. Valid values are:
To get the principal axes for components 1-5:
*createmark comps 1 1-5
hm_getprincipalaxes comps 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
