hm_getelemcheckelems
Returns the elements from within a selection that match the specified element check criteria.
hm_getelemcheckelems mark_id dimension check_type check_mode ?threshold? ?tolerance? ?time_failure?
HyperMesh Tcl Query Command
This command returns the elements that match the specified element check criteria. Only the elements on mark_id and of the specified dimension are considered when determining which elements match the specified criteria.
- mark_id
- The ID of the mark containing the elements. Valid values are 1 and 2.
- dimension
- The dimension of the elements on mark_id to consider. Valid values are:
- check_type
- The type of element check to return the bounds from. The allowable values depend on the dimension specified:
- check_mode
- The type of element check to perform. Valid values are:
- threshold
- The threshold value to use when check_mode is set to above, below or exact. This is ignored and not required when check_mode is set to max or min
- tolerance
- The tolerance value to use when check_mode is set exact. This is ignored and not required when check_mode is set to max, min, above or below.
- ?time_failure?
- The value to use as a threshold beyond which the input elements should be considered to have failed the test. This is required only when check_type is set to addedmass.
Examples
To get the 1D elements that have the minimum length from the elements in comp1:
*createmark elems 1 "by collector name" comp1
set elems [hm_getelemcheckelems 1 1 length min]
To get the 2D elements that have the maximum warpage from the displayed elements:
*createmark elems 1 displayed
set elems [hm_getelemcheckelems 1 2 warpage max]
To get the 2D elements that have a warpage above 5.0 from the displayed elements:
set elems [hm_getelemcheckelems 1 2 warpage above 5.0]
To get the 3D elements that have a tetracollapse below 0.1 from all elements:
*createmark elems 1 all
set elems [hm_getelemcheckelems 1 3 tetracollapse below 0.1]
To get the 3D elements that have a jacobian of exactly 1.0 from all elements, with a tolerance of 0.01:
set elems [hm_getelemcheckelems 1 3 jacobian exact 1.0 0.01]
# Handle error
}Version History
10.0
2019 - Added new check_type values minlength and maxlength for both 2D and 3D, and ortho_3d and size_ratio_3d for 3D.
