hm_latestentityid
Returns the ID of the last created entity.
hm_latestentityid entity_type ?num?
HyperMesh Tcl Query Command
Returns the ID of the last created entity. An option is also available to return the ID of previously created entities (up to 99).
- entity_type
- The type of entity to return the last created ID for.
- num (optional)
- Queries a specific entity created previously before the last entity. The maximum is 99. Default is 0 (last entity).
Examples
To get the latest created component:
hm_latestentityid compsTo get the previous latest and first previous 10th created
component:
*createmark lines 1 100
#Create two nodes on the line
*nodecreateonlines lines 1 2 0 0
#Get the last created node
set node1 [hm_latestentityid nodes]
#Get the first previously created node
set node2 [hm_latestentityid nodes]Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
