hm_ce_alldetailsget
Returns all custom details assigned to a connector.
hm_ce_alldetailsget id reserved
HyperMesh Tcl Query Command
- id
- The ID of the connector to query.
- reserved
- Reserved for future use. Must be set to 0.
To get all the details associated with connector ID 1:
hm_ce_alldetailsget 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
