hm_entitylist
Returns a list of names or IDs of all entities of the requested type.
hm_entitylist entity_type list_type ?mode?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- list_type
- The type of list to generate. Valid values are:
- mode
- An optional argument that specifies which entity types are returned:
To get the list of node IDs:
hm_entitylist nodes id
To get the list of component names:
hm_entitylist comps name
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019 - Added new optional mode argument.
2021.2 – Added new option solvername for the list_type argument.
