hm_getmodelcheckcorrectvalue
Returns the value for a given correction.
hm_getmodelcheckcorrectvalue correction_display_name
HyperMesh Tcl Query Command
- correction_display_name
- The GUI display name of the correction. This is case sensitive.
Examples
To get the value for the "Delete unused materials" correction:
hm_getmodelcheckcorrectvalue "Delete unused materials"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
