hm_getqephtimestep
Returns the time step calculated from QEPH elements in a component.
hm_getqephtimestep name
HyperMesh Tcl Query Command
This command returns the time step calculated from QEPH elements in a component.
- name
- The name of the component
To get the time step from component named "Flange":
hm_getqephtimestep "Flange"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.130
