hm_gettimestepaddedmass
Returns time step added mass for Radioss and Dyna.
hm_gettimestepaddedmass entitytype=<value> mark=<mark_id> ?definition=<value>? ?value=<value>?
HyperMesh Tcl Query Command
Returns the following value of time step added mass for the specified entity.
- entitytype=<value>
- The input entity type.
- mark=<mark_id>
- The ID for the mark containing the input entities. Valid values are 1 and 2.
- definition=<value>
- The time step definition:
- value=<value>
- The time step value. Valid for definition set to 1.
Examples
To get time step added mass of all the components in the
model:
*createmark comps 1 all
hm_gettimestepaddedmass entitytype=comps mark=1To get the time step added mass for a user defined time step of
0.005:
hm_gettimestepaddedmass entitytype=comps mark=1 definition=1 value=0.005Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
