hm_ce_getunsyncdata
Returns data which are not synchronized from the connectorcontrol assigned to a connector.
hm_ce_getunsyncdata id option
HyperMesh Tcl Query Command
- id
- The ID of the connector to query.
- option
- 0 - Returns common data
Examples
To get unique data from the connector with ID 101:
set unique_data [hm_ce_getunsyncdata 101 1]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
