hm_ce_mesh_imprint_option_set
Sets a mesh imprint option value.
hm_ce_mesh_imprint_option_set name value
HyperMesh Tcl Query Command
- name
- Valid names are:
- value
- The value of the option, 0 or 1.
To set the value of avoid_imprint to 1:
hm_ce_mesh_imprint_option_set avoid_imprint 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
