hm_modelcheckneedscorrection
Determines if an auto correction is required for a given check.
hm_modelcheckneedscorrection ?check_display_name?
HyperMesh Tcl Query Command
Returns 1 if an auto correction is required for a given check. Checks with auto correction should be run and have failed entities before running this command.
- check_display_name
- The GUI display name of the check. This is case sensitive.
Examples
To get the correction status for the "Unused materials" check:
hm_modelcheckneedscorrection "Unused Materials"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
