hm_jobs_authenticateServer
Authenticates a server.
hm_jobs_authenticateServer name username password
HyperMesh Tcl Query Command
Authenticates a server. No authentication is required for a local server.
- name
- The name of the server to authenticate.
- username
- The username to use to authenticate.
- password
- The password to use to authenticate.
To authenticate the server named HWUL:
hm_jobs_authenticateServer HWUL myuser abc123
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
