hm_gettotalcog
Returns the center of gravity of the entire model.
hm_gettotalcog
HyperMesh Tcl Query Command
Returns the center of gravity of the entire model including solvermasses, rigidwalls and so on.
Examples
To get the model center of gravity:
set totalcog [hm_gettotalcog]
set COGX_model [lindex $totalcog 0]
set COGY_model [lindex $totalcog 1]
set COGZ_model [lindex $totalcog 2]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
