hm_tabletomark
Append the entity IDs from the named table to the specified mark.
hm_tabletomark table_name mark_id
HyperMesh Tcl Query Command
This command appends the entity IDs stored in table_name to mark mark_id. Valid mark_ids are 1 and 2.
Tables are not stored within a HyperMesh database (.hm file). When the current model is deleted or a new model is loaded, all tables are cleared.
If a table contains an entity that is subsequently deleted, the entity is removed from the table. Renumbering does not modify the entity IDs stored in the table.
To put the elements from table
elem_table on element mark
1:hm_tabletomark elem_table 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}If table_name does not exist, you will get the following
error:
hm_marktotable: the table <table_name> was not found.If mark_id is invalid, you will get the following
error:
hm_marktotable: invalid mark mask <mark_id> specified, must be either 1 or 2.If mark_id is empty, and ?force? is not specified or
is specified as
0:
hm_marktotable: no entities were found on the mark.Version History
2023 - Deprecated argument panel_sensitive.
