hm_wadlinesgetwadline
Returns coordinate data defining a WAD line.
hm_wadlinesgetwadline distance
HyperMesh Tcl Query Command
- distance
- The distance from ground level for the WAD line, as measured along the vehicle. The data will be returned as a list of doubles. Every three doubles are the X, Y, and Z coordinates of a point along the line. The lines run from left to right.
To setup and extract WAD lines data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesend
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
