hm_wadlinessetaxes
Sets the origin and coordinate axes for a WAD lines analysis.
hm_wadlinessetaxes origin_x origin_y origin_z forward_x forward_y forward_z left_x left_y left_z
HyperWorks Tcl Query Command
- origin_x origin_y origin_z
- Defines the X, Y and Z coordinates of the origin. Must be at the vehicle centerline (default 0,0,0).
- forward_x forward_y forward_z
- Defines the vector pointing toward the front of the vehicle (default 1,0,0).
- left_x left_y left_z
- Defines the vector pointing toward the left side of the vehicle (default 0,1,0).
To setup and extract WAD lines data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesend
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}None.
Version History
12.0.110
