hm_getactiveplotcontrolmaxvalue
Returns the maximum value for the active plot control together with the entity ID.
hm_getactiveplotcontrolmaxvalue plot_type entity_type mark_id
HyperMesh Tcl Query Command
Returns the maximum value for the active plot control together with the entity ID. There can be only one active plot control for every plot type.
- plot_type
- The type of plot for which the result values are queried. Valid values are contour, vector, and tensor.
- entity_type
- The entity type for which the values are queried. The valid values are nodes, elements, and components.
- mark_id
- The ID of the mark containing the entities that are considered in the evaluation.
Examples
To get the maximum value of the active contour plot for displayed nodes and the corresponding node ID:
*createmark nodes 1 displayed
hm_getactiveplotcontrolmaxvalue contour nodes 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
