hm_ce_getsolverprojectionbymark
Returns the solver projection data.
hm_ce_getsolverprojectionbymark entity_type1 mark_id1 entity_type2 mark_id2 option solver_id
HyperMesh Tcl Query Command
Returns the solver projection data. The data is returned as a list of lists containing:
{node_id, {x, y, z}, elem_id}
where {x, y, z} is the coordinates of the projection point.
- entity_type1
- The first entity type. Valid values are nodes and elems.
- mark_id1
- The ID of the first mark of entities. Valid values are 1 and 2.
- entity_type2
- The second entity type. Valid values are comps and elems.
- mark_id2
- The ID of the second mark of entities. Valid values are 1 and 2.
- option
- 0 - use_RBE_only=0
- solver_id
- Must be set as 12 for OptiStruct.
Examples
To query the projections for nodes 1-10 and comps 3 and 4:
*createmark nodes 1 1-10;
*createmark comps 2 3 4;
set node_prj_pairs [hm_ce_getsolverprojectionbymark nodes 1 comps 2 0 12];
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
