hm_ce_getconnectorcontrol
Returns connector control or connector control default information from a connector.
hm_ce_getconnectorcontrol id
HyperMesh Tcl Query Command
Returns the type, ID, and name of the connector control/connector control default assigned to a given connector.
- id
- The ID of the connector to query.
Examples
To get the connector control or connector control default for the connector with ID 101:
set ctrl_info [hm_ce_getconnectorcontrol 101]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
