hm_getelementcheckmethod
Returns the method (solver) currently being used for calculating specific element quality checks.
hm_getelementcheckmethod check_name ?method_mode?
HyperMesh Tcl Query Command
This command returns the ID of the method (solver) used to calculate the specified element quality check. For element quality check parameters, their meanings and allowable values, see the *elementchecksettings command.
- check_name
- Specifies the element quality check parameter to query. Valid values are:
- angle
- aspect_2d
- aspect_3d
- cell_squish_2d
- cell_squish_3d
- chord_dev
- equi_skew_2d
- equi_skew_3d
- jacobian_2d
- jacobian_3d
- min_len_2d
- min_len_3d
- ortho_3d
- size_ratio_3d
- skew_2d
- skew_3d
- solver
- taper
- tetra_collapse
- time_step
- warpage
- get_method_mode
- An optional parameter specifying the mode of retrieving of the returned method. Valid values are:
To retrieve the method currently being used for calculation of the aspect ratio for 2D elements:
set aspect2dmethod [ hm_getelementcheckmethod aspect_2d]
To retrieve the method currently being used for calculation of the Jacobian for 2D elements:
set jacobian_method [ hm_getelementcheckmethod jacobian_2d]
# Handle error
}Version History
10-SA1-110
2019 - Added new check_name values ortho_3d and size_ratio_3d.
2020 - Value 5 (Nastran) is now supported for return for check_name aspect_2d.
