hm_getcriteria
Query the values of global mesh quality criteria.
hm_getcriteria criteria
HyperMesh Tcl Query Command
- criteria
- The name of the criteria to query. Valid values can be found in *criteria_update.
Examples
To get the 2D min size:
hm_getcriteria min_size_2d
To get the 3D aspect ratio:
hm_getcriteria aspect_ratio_3d
To get all values:
hm_getcriteria
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
