hm_attributelist
Returns a list of all attribute IDs or names assigned to a specific entity for the current template.
hm_attributelist entity_type entity_name_or_id value ?search_type?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- value
- The type of list to return. Valid values are:
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
Examples
To list the attribute IDs for the current template assigned to mat ID 6:
hm_attributelist mats 6 id
To list the attribute names for the current template assigned to mat name 6:
hm_attributelist mats 6 name -byname
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-110
