hm_getresults
Returns results data.
hm_getresults id=<value> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Query Command
<option>=<value> options can be provided in any order.
- id=<value>
- The ID of the result entity to query.
- contour=<value>
- 0 - Do not contour
- dataname=<value>
- The query data type. Valid values are:
- dataset=<value>
- The data type scalar, tensor or vector.
- derived_subcase_id=<value>
- The subcase ID for derived subcases of type envelope or lsp.
- fileid=<value>
- The file ID corresponding to the unique ID of the result file from the result entity.
- fileid_subcase=<value>
- The unique combinations for considering multiple subcases, separated by colons. For example 1:1,2:1,3:1,4:2
- resultcomponent=<value>
- The component when dataset is tensor or vector.
- step=<value>
- The step index for a given subcase.
- subcase=<value>
- The subcase ID within the result file.
- type=<value>
- The derived loadcase type, either envelope or lsp (linear superposition).
- xml=<value>
- The complete file path of the XML file that holds the inputs for results query.
Generate a vonMises Stress contour for subcase 1 and step 0 for file 1 in result ID
1:
hm_getresults id=1 dataset="Stress" resultcomponent="VonMises" fileid="1" subcase=1 step=0 contour=1Get the envelope derived subcase data for result ID
1:
hm_getresults id=1 type=envelope dataname=UniqueDerivedSubcaseGet the complex filter options for file ID 3 and subcase 5 for result ID
1:
hm_getresults id=1 fileid=3 subcase=5 dataname=complex_filterGet the complex filter options for multiple file IDs and subcases for result ID
1:
hm_getresults id=1 fileid_subcase=1:1,2:1,3:1,4:2 dataname=complex_filterErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
