hm_ce_xmlstringget
Returns connector information in XML format.
hm_ce_xmlstringget id
HyperMesh Tcl Query Command
- id
- The ID of the connector to query.
To get the XML formatted information for connector 100:
hm_ce_xmlstringget 100
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
