hm_estimategeomthicknesslimits
Returns the minimum and maximum thickness limits for thin solid geometry.
hm_estimategeomthicknesslimits entity_type mark_id ?elem_size?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query. Valid values are surfaces and solids.
- mark_id
- The ID of the mark containing the input entities.
- elem_size (optional)
- The element size to be used for internal meshing.
To find the thickness limits for solid ID 100:
*createmark solids 1 100
foreach {min max} [hm_estimategeomthicknesslimits solids 1] {}
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
