hm_comparegetdistanceentitytype
Returns the entity type for a specific distance index.
hm_comparegetdistanceentitytype distance_index
HyperMesh Tcl Query Command
Returns the entity type for a specific distance index. This must be preceded by a call to a relevant hm_compareentities* command and hm_comparefinddistances.
Possible return values are:
- 2 - Elems
- 5 - Surfs
- distance_index
- The index of the distance to query, starting with 0. The number of distances can be found using hm_comparegetdistancecount.
To find the entity type for distance index 0 for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
hm_comparefinddistances 1.0 1
set entity_type [hm_comparegetdistanceentitytype 0]
hm_compareend
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
