hm_getmodelcheckenttype
Returns the entity type for the specified Model Check check display name.
hm_getmodelcheckenttype display_name
HyperMesh Tcl GUI Command
This command returns the entity type for the specified Model Check check display name.
- display_name
- The check display name.
To get the entity type for the check named "Unused Materials":
set enttype [hm_getmodelcheckenttype "Unused Materials"]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
