hm_holedetectionidentifyhole
Returns the hole index for a given node or line.
hm_holedetectionidentifyhole id
HyperMesh Tcl Query Command
Returns the hole index for a given node or line. This must be preceded by a call to hm_holedetectionfindholes.
- id
- The ID of the node or line to query.
To query the hole associated with surface edge 123:
hm_holedetectioninit
*createmark surfs 1 all
hm_holedetectionsetentities surfs 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
set h [hm_holedetectionidentifyhole 123]
hm_holedetectionend
close $holesfile
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
