hm_postcardeditorforentity
Posts a card editor for a selected entity.
hm_postcardeditorforentity entity_type entity_id ?title?
HyperMesh Tcl Query Command
This command posts a card editor for a selected entity.
- entity_type
- The type of entity to post the card editor for.
- entity_id
- The ID of the entity to post the card editor for.
- title
- The title of the card editor dialog. The default title is “Edit <entity type>”.
To display a card editor for the component with ID 2:
hm_postcardeditorforentity comps 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
