hm_collisioninit
Initializes the collision detection module.
hm_collisioninit ?config? ?tolerance? ?allowable_depth? ?min_overlap?
HyperMesh Tcl Query Command
Initializes the collision detection module. This must precede any calls to hm_collisionentitycreate and hm_collisioncheck, and must be followed by a call to hm_collisionend.
- config
- The configuration that defines the collision behavior. This value is obtained by running hm_collisiongetconfig. Default is 0.
- tolerance
- The tolerance to use for intersection checks (for hm_collisiongetconfig intersect_planar keyword) or penetration checks (for hm_collisiongetconfig penetrat_min_overlap keyword). If not specified, the default is 1.e-08.
- allowable_depth
- The allowable depth to use when finding and reporting interferences. If specified, config should be 0 and tolerance should be -1.0. If not specified, this is ignored.
- min_overlap
- For allowable_depth, in cases where collision entities overlap, there may be many intersections, and sorting out which ones are false or not is expensive. This option allows for calculating percentages by measuring the number of intersection segments against the half the number of nodes in each collision entity. If both percentages exceed the min_overlap value, we do not perform the allowable_depth analysis and instead report all of the intersections as true.
To find intersecting surfaces from IDs
1-10:
*createmark surfs 1 1-10
hm_collisioninit
hm_collisionentitycreate surfs 1 0 1 0 0 0 0 0 0
hm_collisioncheck 0 0 1 0 0 0 0
hm_collisionend
hm_getmark surfs 1To find penetrating surfaces from IDs 1-10, using the thickness assigned to the surface
components:
hm_collisioninit
hm_collisioncheck 0 0 0 1 0 0 0
hm_collisionend
hm_getmark surfs 1To find both penetrating and intersecting surfaces from IDs 1-10, using the thickness
components:
hm_collisioninit
hm_collisioncheck 0 0 1 2 0 0 0
hm_collisionend
hm_getmark surfs 1
hm_getmark surfs 2To find both penetrating and intersecting surfaces from IDs 1-10, using the thickness
assigned to the surface components, and using an allowable depth of
0.1:
hm_collisioninit 0 -1 0.1
hm_collisionend
hm_getmark surfs 1
hm_getmark surfs 2Errors
None.
Version History
11.0.130
2017.2 - Added new optional argument min_overlap.
